Key Features
Benefits
Wholesale Hosted Communications (WHC) Express, channel partners can now offer a new digital phone line for their small business customers that will deliver digital calls over a broadband network and will replace the analogue phone services which will be retired by 2025.
Designed for businesses with 1 – 10 employees, WHC Express provides the ultimate flexibility for users to make and receive calls on the same number - across their fixed and mobile devices - with the same call features across them all, such as voicemail, call divert, call transfer and call hold.
The WHC Express APIs provide an alternative ordering option that enables you to fulfil new orders directly to BT’s systems giving you a more powerful and flexible way to connect your own applications to BT.
Ability to:
New to Wholesale Hosted Communication Express and want to find out more about the product in general, then click here. Existing customers who want to review some of our documentation should click here to access product literature from the Document Centre.
Place orders for Wholesale Hosted Communications Express from your systems to BT Wholesale HubCo.
Check whether a particular number range (for WHC Express you can only port a particular number not number range) can be ported based on portState value in response.
Validate the service provider information and the data they are using, in order to prevent potential duplicate order failures.
