Key Features
Benefits
APIs Included
EE
BT
Sim Swap - CAMARA
Digital Identity
CAMARA
The SIM Swap API provides real-time access to information about the most recent SIM card change associated with a mobile number. It supports two key functions: retrieving the exact timestamp of the last SIM swap, and checking whether a SIM change occurred within a specified time window (e.g. the last 24 hours). This is particularly useful for fraud prevention in scenarios like high-value transactions, password resets, or onboarding. The API is consent-based, privacy-preserving, and aligned with CAMARA and Open Gateway standards.
SIM Swap – CAMARA adds a critical layer of security by identifying recent SIM changes that may indicate fraudulent activity. It helps businesses make informed decisions during authentication and transaction flows.
API interface is used by an application to get information about a mobile line latest SIM swap date. It can be easily integrated and used through this secured API and allows SPs (Service Provider) to get this information an...
