Skip to main content
Authorization Flows
  • CAMARA
  • Digital Identity
Our CAMARA APIs support multiple secure authorization flows, allowing seamless and flexible integration across diverse application scenarios.
Our authorization framework supports both the GSMA‑standard CIBA flow and the Mobile Connect Authorization Code Flow, enabling secure, mobile‑network‑verified authentication across a wide range of applications. These flows allow users to authenticate effortlessly through their mobile operator—either silently in the background with Mobile Connect or via a guided consent journey with CIBA. By leveraging strong SIM‑based identity signals, the platform ensures high‑assurance user verification, reduces fraud, and delivers a seamless, privacy‑preserving experience for developers and end users alike.
Mobile Connect Authentication (Authorization Code Flow)
When to use Mobile Connect
Use Mobile Connect when:
  • The user is present and can be redirected to their operator for authentication
  • You need a familiar, browser-based consent experience
  • You are integrating with existing OpenID Connect style journeys
This flow has historically been used for BT and EE identity-backed APIs and was previously bundled directly into API specifications. As flows are now separated, scope usage must be explicitly documented.
Supported scope values
The following scopes are supported in the current Authorization Code flow.
API Scopes
KYC Match openid kyc-match
KYC Fill‑in openid kyc-fill-in
KYC Age Verification openid kyc-age-verification
KYC Tenure openid kyc-tenure
Scam Signal openid scam-signal
High-level flow
  • Your application redirects the user to the BT authorization endpoint
  • The user authenticates and grants consent
  • Your application receives an authorization code
  • The code is exchanged for an access token
  • The access token is used to call the protected API
  • The exact endpoint details are defined in the OpenAPI specification for each product.
CIBA Authentication
When to use CIBA
Use CIBA when:
  • You require a server-to-server or headless integration
  • The user is not actively present in a browser
  • You want to decouple user interaction from API invocation
CIBA is particularly suited to fraud, KYC, and background verification use cases where the consent model is handled separately.
CIBA prerequisites and JWKS requirement
CIBA uses JWT‑based client authentication rather than browser redirects. Partners must host a publicly reachable HTTPS JWKS endpoint so BT can retrieve the public keys required to validate signed authentication requests. Once the application has been created, the JWKS endpoint URL must be provided to your BT account manager so it can be registered against your app configuration. CIBA does not use redirect URIs or front‑end callbacks.
The CIBA flow supports DPV and operation‑specific scopes, aligned to CAMARA.
API Scopes
KYC Match openid dpv:IdentityVerification kyc-match:match
KYC Fill‑in openid dpv:IdentityVerification kyc-fill-in:set-all
KYC Age Verification openid dpv:AgeVerification kyc-age-verification:verify
KYC Tenure openid dpv:IdentityVerification kyc-tenure:check-tenure
Scam Signal openid dpv:FraudPreventionAndDetection scam-signal:verify
High-level flow
  • Your system initiates authentication via the CIBA backchannel endpoint
  • The operator validates the request and user context
  • An authentication result is made available asynchronously
  • Your system exchanges the result for an access token
Select Auth Flow
Back to top
